Hi,<br /><br />Thought you might steer me in the right direction with my problem. I have an older 65 HP Mercury outboard 3 cly.(1975) that has sat outside on a stored boat for 4 years. I was told it ran well when stored ( who knows?) but now doen't turn over. I was thinking of using a special Kroil rust penetrating oil on it which is supposed to penetrate a millionths of an inch. Do you think this is a lost cause? I was thinking of removing the exhaust port cover to inspect the piston /cylinder as well as adding the penetrating oil in the spark plug holes. I am willing to put the effort in if it is possible to free it up. If I have to remove the head, are individual head gaskets available?<br /><br />Since I dont know the reason it is stuck, Any suggestions would be appreciated.<br /><br />Thanks,<br />MM
<br /> <br /><br />Neil Marcus
