Frozen heat exchanger
rangerdave4
Had a brain fart....... heat exchanger froze and blew out the brass ends, besides replacing the ends what else can i expect? or what to look for. i have since took care of the rest of the winterizing.
Thank you for your help.
David
chiefalen
Re: Frozen heat exchanger
Whats that smell like a brain fart. Maybe you got lucky and nothing else happened.
Don S
Many times it cracks the tubes or breaks them loose from the end pieces. After you get it thawed out, pressure check it to see if it held or not.
rangerdave4
The smell is always worse when your not alone when you find the problem ;-)
It bent the ends out about alittle less than a 1/8, the antifreze is still maintaining the same level have diconnected all the fresh water lines
Thanks David
chiefalen
like i said maybe you got lucky.
like mom said, don't do that again.
it's what i call a senior moment.
Ayuh,...
I'd pull the exchanger,+ Pressure Test it....
chiefalen
Just don't go crazy and put 100 psi in it.
10-15 psi for a hour if it don't go down your good to go.
Don't be surprised if you do find a hairline crack. Won't show up till you put pressure to it. Maybe won't even leak.
That Bond-O is good, real, real good.
Saw a guy pressure testing his drive with like 100 psi was wondering why he kept blowing all the seals.
I said 10-15 psi what surprises me is he never read a manual in his life.
