Re: Frozen Drum Brakes and the star adjuster wont budge
The Dico system I had on my old Highlander trailer had one piece drum/hub assemblies, no amount of hammering would remove the drum without first removing he bearings. You may be able to pull the drum off and force the brake shoe retainers to give way, but I've had better luck just getting a stout brake adjusting spoon or thin pry bar over or under the star adjuster and popping it out of place from between the brake shoes. No matter what you do, you need to remove the drum to remove the parts that are seized or about to be knocked loose.
Depending on the size of your tow vehicle and how far or fast you tow whether I'd consider eliminating the brakes in your case, that's a judgement call on your part. I tow my larger boats with a heavy one ton van with strong brakes so its not affected very much by a small trailer. None of my boats weigh over 2000lbs fully loaded and on the trailer.
My Dico master cylinder had a brass or cast iron plug right on top just behind the coupler right in the master cylinder. The master cylinder fill cap is just like those found on old Chevy trucks from the 40's or so. I've seen two types, the hex shaped 1 1/4" or so in diameter cap that screws into the master cylinder top, or the stamped sheet metal type that fits directly onto the master cylinder reservoir. There are several models of DICO surge brakes, thus a few different master cylinder styles. I've never considered any of the DICO systems to be saltwater suitable. The one on my Highlander had a cast iron master cylinder with a cast iron cap that would never seal right, rain water would get into the brake fluid when it rained. I finally began taping the threads with Teflon tape but rust finally got the best of the whole coupler assembly anyhow.
If there's a chance that the master cylinder is still applied, did you try just loosening the brake lines to release pressure? Maybe the master cylinder is just stuck?
Simply removing the outer wheel bearing may gain enough movement to break stuck shoes loose from the drum if their not held in place by stuck wheel cylinders or hydraulic pressure.
The star adjuster has slotted ends, it would need to be pushed up or down out of place, not side to side.
