Frozen Deck Drain
FreeBeeTony
The port side deck drain must have been clogged and is now frozen solid from the cockpit to the scupper.
Should I be concerned?
scoutabout
Re: Frozen Deck Drain
Do you mean there's now a drain tube full of ice? You might be replacing that come spring due to cracking. If you have access to the length of it I suppose you could carefully thaw it with a heat gun, then try to unclog it.
