OK, this has really been a project and need some expert advice. I have a frozen drain plug on my lower unit (merc. 2004 5.0). I haved used a large screwdriver, heat, impact screwdriver, punch, etc. Finally I tried to easy out it, but still no go. I have now taken the lower unit off and have managed to free it, but now have a new problem. When trying to easy out it, I drilled though the threads on the lower unit, particularly where the o-ring seats. I cannot get the drain plug out now as it stops when it gets to that section. I am sure that I will have to have it drilled out. What can I do though to get a new pug in there to seal? Do they have over sized drain plugs to accommodate? Anyone now if there is still a drain plug behind the prop on a 2004 merc B3? I have not looked yet. Thought of it after the damage was done. I don't know if by chance there is a drain on the bottom and behind the prop. Would I be able to take it to a machine shop and have them drill the old one out, re-drill a bit of a larger hole and have them make me a new drain plug to fit? I am looking for options here. If it turn out that there is an extra drain plug behind the prop, what about welding the one at the bottom in the lower unit closed and then just using the one behind the prop going forward. Please help with any options that you think would be of help.
