Hi there, okay, well if solar isn't a "good" option at this point, then what would you suggest for good batteries for my troller? I only need a few hours of runtime from my 24-volt setup and again would really use this in rare occurrences or emergency ones, are there any decent batteries that are closer to 25lbs each to where it would soften the blow on lifting them in and out as I need to take them home to charge? I guess, if I could cut the weight down from 50 to 25lbs that'd be ideal and maybe I"d just settle for that.
I have a back problem and lifting 50lbs up a hill across a busy street times 2 is just something I'd rather avoid. Not saying I'm going to fall apart but at this point, it seems as if my best bet would be to find some good batteries?
Do they make any 12 volt batteries that could run my 68lb pontoon troller (24-volt) that I could just run in series together but weigh 25lbs or close to it (each) or am I SOL in terms of 50lbs+ each and that's it? Anything cost effective you'd recommend?
Thanks,
Mike
Thanks,
Mike
