Front gate swing direction
BOWMAKER1
This may seem like a silly question, but is there any reason not to change the way my front loading gate swings? I have a Fisher 24 something or other with 4 fishing seats up front. My front gate only swings out ward. It won't swing fully open while on the trailer because it hits on the trailer ladder and I have to bungee cord it open to run my trolling motor on the front, and it is hard to load or unload passengers when nosed into a courtesy dock which is usually easier in any kind of wind. The side loading gate does swing inward but not the front one.The hinges are pop riveted to the rail and the gate itself but won't swing the way I want. Also the brackets that hold the bottom legs of the gate are welded in place so I would have to cut them out. Can I get new hinges that would still swing from the same side, the right side looking forward from the console, so that the gate would swing inward? I know that I can cut out the gate to help with the trolling motor problem but I can live with that if the gate would just swing inward and back against my battery storage compartment. Any help will be much appreciated.
BobGinCO
Re: Front gate swing direction
All my doors swing inward.
Old Screwball
All three of my gates swing in. Before you do anything, make sure there aren't any clearance problems. My gates lifts up to clear the floor cleat then swing. Safety latch clears so gate could swing both ways.
Good Luck
Todd4
Drill out all the rivets holding the hinge to the gate and the fence. Rotate the hinge 180 degrees around the vertical axis and re-rivet it back on. In-other-words, the side of the hinge that was riveted to the gate should be riveted to the fence, and the side of the hinge that was riveted to the fence should be riveted to the gate. You may even gety lucky and some of the holes will match back up.
Todd
