fresh water cooling
popey
does fresh water mean a second circuit not just the 'fresh' water from the sea, that runs through the engine?
regards
popey
Re: fresh water cooling
Ayuh,... The Freshwater in a freshwater cooling system is usually Antifreeze, which is cooled by the Raw water from the sea, in the heatexchanger...
45Auto
You are correct, there are 2 water circuits on a fresh water cooled boat.
The engine cooling circuit is exactly like an automobile. It uses anti-freeze and the engine water pump circulates it through the engine block.
The anti-freeze passes through a "radiator" just like a car cooling system.
On a boat this "radiator" is called a "heat exchanger". It forms part of the second cooling circuit. The raw water pump (different from the engine circulating pump) pumps sea water through the heat exchanger, which cools the anti-freeze. The hot sea water then goes out the exhaust, back into the sea.
A heat exchanger is much smaller than a car radiator (usually about 4" in diameter and 18" in length) because it's moving the engine heat from a liquid to another liquid, which is much more efficient than moving the engine heat from a liquid to air.
Jet Wrench
Excellent explanation! It's a good system but more parts/weight and maintenance issues. The engine does stay cleaner not exposed to various water corrosion issues.
JW
magster65
Thus the term "closed cooling". A must in these parts...
havasuboatman
Ensign
The correct terminology makes everything so much easier to explain and understand.
Closed cooling is the correct term. Fresh water is used as the opposite of the Raw water cooling.
