Freeze Plugs Ford Winsor 351 Engine
Mrorak
Ok so i had this boat winterized and the guy i had do it must have done a ****ty job. 2 freeze plugs popped out of the engine and they are right behind the engine mounts. I dont think i can get to them without pulling the engine. Any ideas or suggestions.
Thanks
HT32BSX115
Re: Freeze Plugs Ford Winsor 351 Engine
Howdy,
Those are not freeze plugs. They're there for the casting process.....They were never intended to protect you from a cracked block at all actually.......
If the person that "winterized" your engine did not remove the drain plugs and use a piece of wire or small screwdriver to poke in the holes and clear out the rust flakes and other debris, you may also have a cracked block.
If you're lucky, you may not have a cracked block though. If you cannot get in there to replace the soft plugs, either with new brass or rubber ones, then you'll probably have to pull the engine.
After you do replace the plugs, you should monitor for water in your oil. If the block cracked it may be "in the valley" under the intake manifold for a V-8.
Regards,
Rick
Mrorak
Are they the same size as freeze plugs or a special size for marine use. i have replaced them in a car never a boat?
gdombroski
Had the same thing happen to both engines. No way to get to the two on each side dehind the mounts. My 2955 Avanti had to trailored in and engines pulled. Cost about $1100 couple years ago to replace $20 of freeze plugs. Good news though is that neither block cracked. Your boat insurance may cover it or the shop that did the winterizing. I remember reading somewhere that rubber ones should not be used. Can't remember where or why though.
Good luck
haulnazz15
It would have been a butt-load cheaper to buy or rent an engine hoist for a day and lift the engines up, lol.
Lodgepole
Go gack to the winterizer and demand he take care of the problem. This is what small claims courts are for. He needs to understand this.
gdombroski
Except that I would have had to buy a trailer and something to tow it with.
