Ok my friend's g/f has a newer Fourwinns Horizon RS w/a Volvo Penta 4.3L .and it wont start.<br /><br /> When the key is turned all we hear is fule pump coming on. No clicks or anything else and battery is new. Engine doesnt crank at all.<br /> <br /> We thought maybe it was the ignition switch so i bypassed it and got same results. We checked all fuses they're all good.<br /><br /> She said she used to have a problem with starting it , the throttle would need to be moved back and forth some before it would start. I noticed when we move it while ign is on, you can hear fuel pump turn off.I know how auto electric works and all that but im not familiar with boats and all their safety switchs.I am planning on opening panel and trying to bypass safety switch on throttle to see if its bad.<br /><br /> I was wondering if there was a relay of sorts between the ign switch and solenoid and where it could be.I cant reach to the starter to try and arch the contacts and see if it turns over. What other safety switchs are there also?<br /><br /> I know help is limited to reading about problems.I am trying to think of everything i did to give anyone a better idea of where else to look. Any help is great, before we take it to a mechanic and dish out the $$$
