Four Winns Horizon 175 QX 1998 Speedometer
craig1989
Just picked up a 1998 Four Winns Horizon 175 QX and am very happy so far. However there are a few problem with the gages. I'm new to boating and would like to be able to fix these problems myself it at all possible. The following gages are broken:<br /> <br /> - Speedometer<br /> - Trim Meter<br /><br />Any help on how to fix either of these two problems would be greatly appreciated. However as i said above I am very new to boating so keep that in mind when using boating terms :confused: ;) \<br /><br />Really appreciate it,<br /><br />Craig
craig1989
Re: Four Winns Horizon 175 QX 1998 Speedometer
First off I apologize for double posting but I cannot find the edit option,<br /><br />here are some pics of the set up and by the looks of things the problem, however as i said I still am not sure where the hose should connect and what else needs to be done.<br /><br />
<br /><br />
<br /><br /><br />Any help at all is appreciated.
SpinnerBait_Nut
Hey craig, that rubber hose is suppose to connect to a fitting on top of the pick-up(Pitot tube). Looks like it may be broke off.<br />You will have to replace it if it is.
