Found this in my carbs..
swamp creek
Found this gunk in one of my carbs. I'm guess it is deposits from ethanol gas? I just bought this boat a few weeks ago and ran it, it didn't seem to run like it should. Checked everything i could think of before i took the carbs off. Gonna replace my fuel lines and cleaned this crud out. What else should i look for? Is this in my fuel pump too?
ethanol trying to turn back into corn
geoffwga1
Probably,I'd give your tank a good cleaning out too if it came with the motor.
emdsapmgr
If these engines are stored to a long time with fuel in them, that's the problem. The light part of the gas will eventually evaporate, leaving the gelatin of the fuel as a residue. As it slowly dries out, it will get hard a crusty. New gas won't dissolve old gas, so you are left cleaning the insides of the carbs. Should run much better after a good cleaning with a carb cleaner. That's the only thing that will touch the dried fuel residue. Other areas that are not vented (like the carbs are) may not be much of a problem, such as the fuel pump or hoses. They are not open directly to the air. You may have to replace all the rubber fuel components, for another reason, though. If the engine dates back to the late 79's or very early 80's and has original fuel components-the rubber parts of the fuel system were not made to handle today's ethanol fuels. That includes all fuel hoses and the rubber bladders in the fuel pumps. Usually when these old hoses start to go, they disintegrate and black bits of hose will migrate through the system and fill the fuel bowls. I don't see that in your pictures, but then I cant' get much an enlargement on them, either.
swamp creek
Yeah there were little black speks of rubber in the carbs as well. I think they came off of the mail gas hose, not the ones in the motor itself. The ones in the motor looked to be new. I bought some gas hoses to replace them, but they looked to be new already so I saved them for next time. Yeah this motor sings now. Sounds so much better, Gonna test it out sat.
Barramundi NQ
Yuk! That definitely looks like ethanol residue over just old fuel varnish. A friend of mine with a fiberglass fuel tank decided to save 5 cents a liter and filled up with an e10 fuel. His honda outboard didn't mind it too much, that was until the ethanol began to dissolve the rein in the tank and started to send resin into the fuel filter. That clogged up in about 5mins. His injectors needed to be cleaned and some were replaced. Ethanol is a solvent and I have never heard of anyone with a positive experience in using it in a boat. I have always used premium fuel cause the extra power and higher quality fuel gives me less downtime.
Carb cleaner is your friend:D
HighTrim
Looks to me like some of that is cowl insulation that got sucked in the carb throat? What motor is this? Is there the foam style insulation sprayed into the cowl?
swamp creek
Nah def not insulation. Just crud from old gas. I cleaned it out and put it all back together and it runs like a new motor. Now I have to find out where my pontoons are leaking.
