found an add for 1976 115hp johnson used five times
199675hpforce
No pictures or anything but is 115hp any good? Wants $1500 for the motor, my current boat 96 starcraft fishmaster 170 with 96 75hp force. Im not inlove with the force lol only one carb for three cyl. Will this johnson bolt up to the predrilled mercury force locations? Also can i keep current controls and rig it up
crb478
Re: found an add for 1976 115hp johnson used five times
It is a solid motor, but the price seems high and it will need some work if it has not been run in a while. It will probably bolt up to the holes you have already, but you will need new controls and cables along with the wiring harness for the 115. I would look for a newer 115 something in the 80's or 90's in that same price range. You would have much better parts availability that way.
tashasdaddy
good motor if maintained, parts no problem. condition is everything, it will need new alcohol resistant B1 rated fuel hoses, water pump kit, probably carb cleaning and kit.
BUYING A USED MOTOR
overall condition, condition of the place you are buying it from, usually tells you how they care for things. compression 100 + psi, and within 10% of each other, good strong blue spark, no water in the lower unit oil. look for discolored paint, (sign of over heat at
one time, also scarred up bolts, as why. have them start it. if they fail to put it in a barrell or tank, or on muffs, or in the water, to start it they don't know what they are doing. best yet is to take it for a 30 min to 1 hour test run. also if remote controlled motor, the controls should come with it.
ezeke
The 1976 115 motor is a good motor but is difficult to upgrade because most of the parts and systems were not used after 1977. The power tilt and trim systems, for example, is obsolete and newer ones will not fit. Try to find a 1979 motor or more recent model if you can.
krogie
great motor , and it should bolt right up . i wonder when the last time it was taken out or ran ? the price does seem high especially if i does not come with the controls and harness. i have owned one a few years back and the parts were always easy to come by , and not bad prices. i think all i am doing here is agreing with everybody else. if you can get him to come down on the price and it has been maintained well , it may not be a bad upgrade for your starcraft
jay_merrill
If the motor was really used only five times, it could be a great find. Whether or not the deal is good, is another thing.
First, the motor should look like it was used five times. The original paint should be in excellent condition, with little or no wear. The paint on the prop should be in top condition too.
As you look over the rest of the motor, look for signs that the story being provided is true. I would expect to see old, dried up grease in all of the locations were it is normally applied. I would also expect to see dust and other signs of a motor that has been sitting around. The spark plugs should be original, and should have no visible electrode wear. When you check the gearbox lube, you should see no signs of water intrusion. Look for tool marks on the engine in all locations - if therre are any, its a sign that the motor has been worked on - something that you would not expect with so little use.
Your seller may be perfectly honest, but not all are and you have to approach the sitation from that standpoint. If all checks out, offer a bid that reflects the reality of a motor that hasn't been run in years. You will have to rebuild the carbs, the fuel pump and the water pump, at a minimum. You will also have to remove all the old grease and re-lube the entire engine. In this area, you could have problems at every location that has a zerk fitting, because old grease tends to clog them up. I've actually had to take sections of engines apart, because I couldn't get any grease past a clog in a fitting or channel.
Other parts may need replacement too. As TD said, the fuel lines are an example. Spark plug wires are another possibility, as are any number of other things. Don't forget the basics either - be sure to check compression, etc.
Some folks are scared to death of old motors, but I have found them to be a great bargain, if approached from a reasonable perspective. The trick to buying and owning them is to pay an initial price that reflects true value. I think $1,500 is a bit much too and that is so, because you are going to sink some money into the motor before it ever hits the water. How much money that is depends on alot of things, starting with whether you will do the work or a marine dealer will. If you take it to the shop, you can expect to pay about $1,000 to start. As you use the motor and a few more issues come up, you will pay more. If you can do the work yourself, expect about a third to half that amount.
Let us know how you make out.
dreadinger
I recently bought a 1975 115hp for 400.00. The tilt and trim leaks down but after some seamfoam it has 120lbs compression across the board and fires right up. I love the engine and the price.
F_R
Honorary Supreme Mariner
What's wrong with only one carburetor? One good thing about the Force motors was their simplicity. Nevermind that, the 115 should come with the controls or you are not getting a complete motor. Personally, I think $1500 is a good price if it truly has only been used five times. Compare that with the price of a new one. You can invest in the over due maintenance items and come out with a good motor at low cost.
Unless it went over the falls on the last trip.
199675hpforce
Thanks for the replies who doesnt like a barn yard find lol. Says its scratched up but looks new underneath. What length do i need a 20 inch? Does this year have oil injection tank thingy or premix which im hoping for! Is there a water tell tale? Im thinking of trading 20 gauge berreta shotgun from 60's for it. Who knows maybe this might be a sweet heart of a motor! Or an over priced piece of crap. Im going to call the guy tonight. Does anyone have pics of 1976 115hp? If its blue or white thats great but some 76s came with ugly green paint that would have to be painted! The motor comes with original harness and stuff but off 22 foot cuddy type mines like crestliner super hawk. (Reason i dont like force underpowered and cant seem to get a decent idle going i should check timing, i do like the light weight of motor and tilt works great its mostly mercury.) I can swap out fuel lines,water impeller,tune up with your help)
199675hpforce
Gave the owner a call
tells me there is no tilt or trim? Wouldnt this be standard on 115hp
crb478
the 76 is a premix only unit, does not have the vro. It also does not have a tail tell. Check the compression and spark as well as the lower unit oil. If any onf these are not where they need to be it could get expensive fast, especially with some parts being discontinued.
