Leinenkugel#1
Thread starter- Joined
- May 27, 2008
- 61
1987 force 85 hp. Found a small 1/2 inch crack in lower unit by the exhaust. There is bolt located inside the exhaust, it looks like somebody over tighten and cracked it around the bolt area. There appears to be no water concern getting into the lower unit itself because the crack is inside the exhaust area. Any water getting into the crack, will exit the exhaust and vise/versa . Looks like the crack has been there for a while and the motor runs well. Can you weld that some how? or any other alternatives.
