fouling plugs on proper mix ratio
rstreckjr
I don't know why this is happening maybe you guys could help me out. 1978 rude 140 model #140840c. Running at 50:1 ratio. After about 3 hours of running engine through full range of rpm's I end up fouiling out all 4 plugs. I have change the fuel filter, the fuel/water seperator, multiple times for both with no change, still fouling. If anyone has any fresh ideas please help.<br /><br />Rob
tmcalavy
Re: fouling plugs on proper mix ratio
If they fouling is black, you might try a hotter plug...go up the heat range and see if that fixes it. If not, maybe time to decarbon with some seafoam or deepcreep.
rstreckjr
Ok, they are fouling black, I will go hotter. Do you think it would be ok to go hotter on the heat range while doing the decarbon at the same time? Or do you think I should just try one then the other?
Dhadley
Let's start at the begining and make sure you have the correct plug. What plugs are you running now?
byacey
Carb running rich will cause same problem, possibly and most likely due to a leaking float needle and seat, or a sticking float.
rstreckjr
Dahadley: <br />I am using L77JC4 plugs.<br /><br />Bill Yancey: <br />How would I be able to tell if the Carb is running to rich? Also, is there a way to tell if the float needles are leaking? Please pardon my arrogance I don't anything about Carbs, the rest of the motor I can handle, but Carbs confuse me...<br /><br />By the way everone, Compression checked good on all 4 cylinders, They were between 124 and 128. Coils are sending good spark to the plugs.
Dhadley
Good choice of plugs. When you say they foul after 3 hours running, what do they do or not do? Or are you just seeing them turn black?
byacey
There are various ways to check the needle and float, but the easiest way is to just replace them and inspect the float. Needle and seat are very inexpensive.
rstreckjr
Dhadley: <br />The motor sounds like the plugs are fouled like it is straining to work. I also have an extreme loss of power ( i.e. going from 48mph to 7.5 to 8.5mph ). At that point I have learned to change the plugs on the water and whamo I'm running strong again. The plugs I pull out are black and are heavily coated in oil.<br /><br />Bill Yancey: <br />Thanks for the info, I will look up the part numbers for the needle, float and seat and get them on order.
