Fouled Spark Plugs Hard Starting
D&D
I have a 1983 70HP 3 Cyl Evinrude. Recently I have had trouble starting it after leaving it set up for 2 or 3 months. I found the spark plugs were fouled and full of carbon build up, so I replaced them. The next time I went out I had trouble starting it again, it seemed as if it were not hitting on all 3 cyl. After getting it started it ran and idled fine for the remainder of the trip a total running time of about 1&1/2 hrs. Again I removed the S/Plugs to find carbon built up along with a white milky substance.<br />I took a compression test and found 125PSI in all three cylinders while taking the test a white milky substance ran out of the center plug hole.<br />Can someone help me, and tell were I can get a good service manual? :confused: :confused: <br />I checked and found no water in the gas tank.
Allan19603hp
Re: Fouled Spark Plugs Hard Starting
leaky head gasket??? just a start milky white substance would say gas and oil mix with water... and perhaps bad coil or power pack?????<br /><br />just where i would start
The Marine Doctor
Yep...blown head gasket...and get a better brand of oil to run your engine with. The oil is what keeps the engine clean..not the fuel.<br /><br />TMD
D&D
Fouled Spark Plugs Hard Start<br /><br />I would like to thank all of you for your quick response. But I still have one other question about the blown head gasket. If it were a blown head gasket causing the problem why am I getting a compression reading of 125 PSI?
D&D
Fouled Spark Pugs Hard Start<br /><br />I want to thank all of you for your quick response. But I still have a question today I started up my motor with on problem and ran it for 15 minutes on a fast and low idle. While it was still hot I took another compression check to find that it was still showing 125 PSI in all three cyl. ONLY this time with no WHITE MILKY SUBSTANCE ON THE PLUGS do you still think the problem is a blown head gaskket and if so why the 125 PSI Oh and I have a in line settelment bowl that shows no sign of water.
The Marine Doctor
Water has to be getting in from somewhere...most of the time its the head gasket. May not be in your case. Could be the exhaust gaskets on the side.<br /><br />This is something you will have to keep and eye on and see if it contiues or stops altogether.<br /><br />Another way to get water into the cyl is if the ign cuts out. This is rare..but when the ign cuts out the cyl does not have the hot gasses rushing out the exhaust side, which prevents water from entering the cyl. So when the piston moves down and the exhaust side is open...water will enter the cyl.<br /><br />TMD
D&D
HELLO CAPTAIN<br /><br />Fould spark plugs hard start<br /> <br />Thanks for your quick reply:<br /><br />I am mechanicly inclined so what do you suggest I do next. Try running it again or were should I start looking? Are what would be a fair ball park price to have it fixed by a dealer? I know some dealers will charge me a arm and leg to fix it.
