Ford 302 spark plugs
Jakem
If there was water in there wouldn't it be noticeable out the exhaust. If that's the issue is it repairable?
Jakem
I used new gaskets yes...the manifolds and elbows seemed in good shape..no corrosion or anything. I never lost any coolant anywere. It was never down anyways
Lou C
Remove spark plugs & valve covers & see if will crank over with the ignition disabled. Look for normal valve train movement & see if water comes out of the spark plug holes. That will also reveal if something failed in the valve train.
Jakem
Right o...I'll do some digging today...the engine is under warranty..18 month unlimited hours...my.gut says there going to try and get out of it...
Lou C
If it’s under warrantee might be better not to touch anything other than making sure there is oil in the crankcase and no water in the cyls
Jakem
Oil is full and still clean...I'll pull plugs and see if I can tell anything
Jakem
Here's a pic of spark plugs that had 1 run on them for about half hour in the river yesterday...varied speed and rpm.
Jakem
Lou C
looks to be running quite lean, you would like to see a tan/light brown color on the center insulator. At least it doesn't seem to be burning oil!
Jakem
Cant imagine being leen for short period of time would lock it up though..I spun it back and.forth about 10 times with crank bolt and no water in any that I can see
Scott06
So its no longer locked up now? be careful not to snap the bolt of the crank ...
There is always water in the exhaust in a marine application. If you get enough water into a cylinder since water doesn't compress it can lock an engine up even bending rods. I think it is more typically seen after shutoff water leaking in exhaust manifolds/elbows or cracked heads leak into cylinder, on next start piston comes up, engine gets locked as water wont compress... Easy thing to rule out if it is locked up.
Jakem
Ya it's locked up...not fully like I can go all the way clockwise till it hits something...the counter clockwise till it hits again...
Jakem
Sorry what I meant about wayer in the exhaust I meant white smoke like a head gasket issue
Scott06
you wont notice the water that's not supposed to be in the exhaust from the water that is supposed to be in the exhaust (cooling water exit to overboard goes in exhaust )
