ford 302 hydraulic pump installation help
attila nagy
I have an 88 302 ford that I am rebuilding. I am in the process of putting the accessories on such as the hydraulic pump. The pump does not line up with the pulleys. Did I possibly miss any brackets? Does anyone have a clear picture of an assembled pump? Or, I would love to have a diagram of the accessory installation, like where does the oil pump cooler go? How is it mounted?
Bt Doctur
Re: ford 302 hydraulic pump installation help
Go to the Adults Only section and download the correct manual. Illustrations should be in there.
Bt Doctur
The very second post on the page .under this
Sticky: ------- Water in my OIL !!! Arggggggggggg
attila nagy
Thank you!Thank you!Thank you!Thank you!Thank you!Thank you!Thank you!Thank you!Thank you!Thank you!Thank you!Thank you!Thank you!Thank you!Thank you!Thank you!Thank you!Thank you!Thank you!Thank you!Thank you!Thank you!Thank you!Thank you!Thank you!Thank you!Thank you!Thank you!Thank you!Thank you!Thank you!Thank you!Thank you!Thank you!Thank you!
