force125 cylinder loss
jgibson712
I have a force 125 i have 165 lbs compression on all but the #2 cylinder it holds 30 lbs there is alot of guck on the top of the piston any clues?
revertmastec
Re: force125 cylinder loss
Try decarbon the motor, may get rid of the carbon and free up rings to give you more compression.
jgibson712
well tried the decarbonizing, Didnt work so I got a wild hair and pulled the head. Not Good I have 6 holes in the piston. There is a scar about .030 in the ctlinder wall. Any suggestions on the cheapest yet durable way out?
revertmastec
The cheapest way out would be to bore that cylinder and put a new oversizes piston in.
91Force90hp
I have a similiar problem. No gauge to tell but have very little or no compression <br />in the bottom cylinder. Pulled the head, piston looks OK, and cylinder fairly clean.<br />Should I re-ring it? If so, how much trouble is it to get piston out?? Thanks.
Deerdog
Would agree that the cheapest way in teh short run is to do that one cylinder - especially if the others are at 165 - the topend of the spec for compression.<br /><br />Before you go too far I would find out what caused the holes in teh piston first or you may be repeating the problem in a few weeks after getting back together. Holes being burned in a piston usually come from too lean a fuel/air mix. <br /><br />Good Luck<br />Deerdog
