Force trim leak down
dogboy8
I posted a question earlier about my trim leaking down on my 89 force 125HP Tilt holds great with no leak down since I replaced the seals in the pilot valves in the pump body, but when I tilt it down to the trim cylinder it leaks all the way down over the course of a couple of hours. Also, I just replaced the o-ring in the trim cylinder. I also found that, although the tilt will hold indefinitly when parked, it does leak down while towing. I checked the shuttle valve and it moves back and forth (how easily should it slide??). Also, could I have put the seals in the pilot valves incorectly??? I also swapped out most of the o-rings on the pilot valves. Any help will be greatly appreciated. Thanks Greg
