Force Starting Technique
titleistprov21
Hi Guys,
Quick question that I had also asked within one of my other threads:
When cold starting your Force, do you run the risk of flooding the engine when you use throttle only (fast idle)?
And I read somewhere that the Force engines don't have a conventional choke, but rather some gizmo that actually squirts fuel into the carb?
Please excuse the lack and accuracy of techinical lingo as I am still very much a novice.
Also, BTW, I have a 1997 Mercury Force 90hp.
Thanks in advance!
pnwboat
Re: Force Starting Technique
I've found that using the neutral fast idle position helps get the motor started with fewer attempts. Based on that, I would say that it does not increase the chances of flooding. Engaging the choke too long will definitely increase the chances of flooding. You should only need 2 or 3 seconds of choke on each attempt.
On your particular motor you are correct in that it does not have a conventional choke plate. It has what is called a "fuel enrichment solenoid". It does away with the choke plate. Only advantage I can see is that it does away with the restriction in the opening of the mouth of the carburetor caused by the choke plate and shaft sitting there.
