Re: Force overheating...Help please!!!!
Your compression numbers are low,Noyu. This leads me to suspect the head gasket,or head cover gasket.<br /> This motor does not have a pressure relief valve.<br />It does however, have a wierd shaped intake,as I'm sure you have discovered.<br />These intakes do not provide a good enough seal on the muffs to provide enough water to the impeller. These engines do not have a normal telltale like most outboards. The two exaust ports behind the motor on the leg, emitt both exaust and water. As long as you have a spray or mist, it is isuing just fine.<br />The best way to run this motor out of water, is to submerge the lower unit past the cavititation plate in a large garbage can. I have one set asside for this purpose,and installed a drain at the bottom of the can to drain it (the can,that is).<br /><br />Your compression should be equal on both cylinders, even if they are low. If so, I would suspect a carbon restriction in the exaust ports. Sometimes, a can of decarbon cleaner will restore this lost compression, and greatly improve performance.<br />However, if this carbon has gotten really bad, a teardown is the only way to remove it.<br />Switch to a higher grade of oil also. Wall Mart's "Supertech" TW-C3 oil is cheap and good.
