tmiller4090
Thread starter- Joined
- Sep 15, 2002
- 30
I have a 1988 85 hp force,I removed the shift pivot screw and had to tear the l/u down to fix it all has went well.the only thing bothering me is that now whe I shift into forward or reverse the prop is locked both ways. in neutral it spins free both ways .I can put it in forward and turn the flywheel and the prop turns correctly,In reverse the prop turns the opposite direction.I have unhooked the shift lever and worked with it manually but the prop always locks both ways. I have not started the motor since the repair.Is the prop suppost to lock both ways on this motor?If not any suggestions?---Troy
