fishthebay
Thread starter- Joined
- Aug 17, 2001
- 180
Hello everyone-<br /><br />The engine is a 1987 85HP FORCE. I did a post the other day for some opionions on low idile or stalling when first engaged in gear, UNLESS you give it a little more juice than normal.<br /><br />I went down to the boat today and it started fine. After warmed up (about more than a minute) the motor starts to idile lower than normal. If you put it in gear to get out of the slip it wants to stall, UNLESS you give it a little more juice.<br /><br />Other than that the motor runs great at all speeds including WOT.<br /><br />Since I was going to leave my boat at the slip for a few more days prior to going out I disconnected the fuel line (recommended by a few other posters) and let it run out of fuel. As it starts to run out of fuel the idile increases (as its starving for fuel), but it runs really great as the idile moves up.<br /><br />I do have a manuel for the motor and think I need to do an adjustment on the carbs to bring the idile up a bit.<br /><br />Its says 1 1/4 turns out for lightly seated position.<br /><br />My question is do you think based on the info I have given that this will remidy the problem?<br /><br />Secondly, prior to started the ajustment on the carbs how do I go about doing this?<br /><br />Do I start the motor and let it warm up and then start at the top carb, go to slighly seated and then back off 1 1/4 turns and move on the next?<br /><br />Or do I lightly seat each carb first without starting the motor, make the 1 1/4 turns out and then start and make modifications as when it warms up?<br /><br />Suggestions appreciated.<br /><br />Thanks everyone.....
