814minihulk
Thread starter- Joined
- Mar 11, 2020
- 4
Hello, I have a 1996 Force 75hp. I rebuilt the entire lower unit this past winter and am having an issue with it not going into neutral or reverse. The thrust washer is installed correctly. I seem to not be able to figure out the issue. Does anyone have any ideas as to what could be causing this? As you move the throttle you can see it moving on the engine but for some reason the prop is staying locked in the forward gear.
Any advise would be greatly appreciated. Thank you!
