Force Flywheel
Ron Regan
are there any special tool needed to pull flywheel from 87--50 hp force?<br />thanks<br />Ron
Re: Force Flywheel
it should be the same as my 150 force, a harmonic ballancer puller from auto parts store<br /><br />you will need to buy three (grade 8) 1/4 inch 20thread bolts.
lonewolf5347
Re: Force Flywheel
KonRon a harmonic ballancer puller like dave in toledo has mention all so what helps is a impack gun when I removed my flywheel on my 120 hp force the impack gun made the difference.
Ron Regan
Re: Force Flywheel
Thanks guys<br />I have both a harmonic balancer puller and several impacts,also a cutting torch if things get too fustrated.I guess I'll do a complete tune up.I did'nt know that a 87 year had points.The motor runs and sounds good but I have had many vehicles with points and don't know how long the motor has been sitting.<br />Thanks again<br />Ron
