I have a 90hp Force L-Drive. The motor runs great and the only problem I'm having is when it's in the water she will not stay running when I try to put her into gear. The idle seems too low. It will idle but it's very low and when I put her into gear it just dies!..Sometimes I catch her just right and she'll move. But it takes alot of restarting to get her to finally take off. If I could just set the idle a little higher, I think I would be OK. It has 3 carbs. How do I adjust the idle? And does this sound like a idle problem?<br /><br />Like I sais it does idle but very low. Stalls when engaging into gear.<br /><br />Thanks!
