Bigprairie1
Thread starter- Joined
- Jun 13, 2007
- 2,568
I was just reading in my newly acquired Cylmer manual that the compression readings in the Force engines are not necessarily designed to be the same on all cylinders. I thought this was pretty interesting info because it would have a bearing on the interpretation of results from any compression testing. Particularly if one was assuming that the reading should all be about the same.
On some 3 cylinder engines (ie: 90hp/120hp) the 1st cylinder are supposed to be about 10-15 psi lower than than #2 and #3 cylinders. On the 4 cylinder engines the lower compression should be on the #1 and the #4 cylinders.
This is pretty interesting...anyone know of this or heard of this on the Force engines?
I guess if I'm getting a slightly lower compression reading on my #1 cylinder....it might just be designed to be so?
I'll have to recheck my serial/model no's to see if it applies to either of my Force 90hp's before resolving my compression tests.
