executivos1
- Sep 18, 2008
- 4
Hi, I have a 1987 Force 125...
We went to rebuild the carbs...I'm told the kit I needed is fk10103-2. I bought 2 of those and we went to work.
The problem is that each kit came with 2 needles, and both of them were a little 2 long. (or longer than the ones that were in my carbs)
We kept one of the old needles in, the other float/needle connection wasn't working (when turned upside down and blown on) so we simply grinded the back of the needle down until it fit.
Took the boat out on the water and it won't get about 8 mph, any more throttle and it goes to stall (too much fuel) Also if going slow AT ALL, it would stall...in neutral it would stall...trying to change from forward to reverse it would stall which meant trying to dock and trailer the boat at uncomfortable speeds.
I took it to a dealer and he said that the top carb (the one using the old needle) was flooding but didn't say anything (and was having trouble locating parts). I took the boat home and we grinded the other new needle down and put it in. I took the boat out again and now it's running better---top speed about 20 mph, but more importantly it's running pretty well at low speeds and doesn't stall. If I give it more gas above 20mph it does the same thing as before....starts to stall out too rich
Anyway, I should be getting around 35+ or at least be able to reach wot. Has anyone else had to grind down their needles? Am I missing something? it has been verified by mercury that I'm using the right part kit.
btw, i have new spark plugs, my compression is 140 across the board and the dealer says that my ignition is all great.
