force 90hp water in cylinders
force 90hp
Hi all,newbie here have 1990 force 90 hp engine on 24ft pontoon and was goin down river about 1/4 throttle and just died thought I ran outta gas but upon further inspection after i pulled plugs out they had water on them! need help with this one. Thanks:confused:
Sprky
Re: force 90hp water in cylinders
Pull a fuel sample and see if that is your water source.
From running to not with water in all cyliders is usually water in the fuel.
Chris
bentle
Hook up a portable fuel tank with good mix. 50:1 ratio 87 octane and see how she runs. If same problem then you have a blown head gasket. A force manual for your motor is a must if you plan to repair yourself.
force 90hp
Thanks to all that replied.will check these things out!I just happen to be on vacation this week too!!
Sprky
If you hook an external tank to a motor full of water, you still have a motor full of water and it will not run.
Pull a fuel sample first. If it has water in it then clean the fuel system and start with fresh fuel.
If not, then explore other avenues.
force 90hp
Well you guys were right!It was water in bottom of backup gas tank!! Thanks again! Almost took the head off!
:D
