Force 90 on Bayliner capri 1800 top speed
wkraus
I have a 1990 Capri 1800 with a force 90 on it. I hit 35 with me and a passenger. We went out last night with 5 people total and brought a tube. It took forever to get to a plane and seemed real sluggish. I am told that the force motors are under powered compared to their ratings and am probably only getting around 75 horse. My question is.. The boat is rated up to a 125 horse. What kind of speed can I expect if I upgrade? I know I do not want a mercury or force again. My prop is currently a 17. Would changing this help me? I can't stand how doggie it is. Thanks!!!!
anple
Re: Force 90 on Bayliner capri 1800 top speed
1997 Maxum 17' with Force 120hp, 21p aluminum prop hit me around 47 miles/hr at WOT.
JB
Whoever told you that makes us ethical liars look bad. It is pure hogwash.
Bustedknuckle84
I had 5 people on my 20 ft bayliner, 1 of them was a heavier guy, i couldnt plane either. threw him up front and we planed just fine :D
My force seems solid, just wish boat parts were easier to find.
Chris2485
I also have the a bayliner 18 with a 90 HP Force. I'm definitely learning by fire with this boat as I bought it used. As a first time boat owner I had the same issue last summer. I put planer boards on the outboard force and it definitely helped. I typically can get speeds about 37mph with myself, wife, a few kids. Having a few of the larger people sit towards the stern also helps plane even faster.
Robert D
Weight is the issue, as well as where it is located. The fin on the lower unit will help get it up, but take a few mph off the top end. Make sure you're not full of waterlogged foam under the deck, also. 150hp Force on a 17'6" trihull, no gear, just me and I can hit 60mph on smooth water. 5 adults, three 6 gallon fuel tanks, and we're down to 41 mph....
