force 90 hp help!!!!!!!
thinktexas
:confused: My husband and I bought a 1990 bayliner with a 1990force motor...first time we took it out the alarm went off...let it cool for like 5 minutes and we took off..it worked fine...then we took it out this weekend and the alarm would keep going off but once you take off the alarm would shut off...the boat still has water coming out from the back ...it didnt smell like nothing was burning....my brother-in-law did say that the water coming out was warm(dont know if that matters.) what happens is that it does turn on it idles the alarm goes on and then when you put it into gear (drive) it turns off...we kept trying it but it never came back on..things we tried...
gas and the ratio of motor is right...yesterday he tried the air filter no blockage...tried the hoses where the gas is supposed to gush out none of it did..... nothing came out..(i really dont know if my husband know what he is doing)..so can somebody please give me some experience advice..will try anyhting...he thinks it needs a new fuel pump b/c of gas thing...
also said when water comes out its a little gushing not alot...
so new water pump..and thermostat....
so what do yall think???
desperate in Texas....
thank you:cool:
roscoe
Re: force 90 hp help!!!!!!!
Worn out water pump impeller and possibly the thermostat as well.
You need:
A Clymer Force service manual. (Try ebay)
A water pump impeller and thermostat. (any Mercury dealer)
baxtr
Very easy do it yourself fix as long as you follow roscoes first tip
: [size=+2] Get a service manual[/size]
