FORCE 89 50HP damaged cyliner & piston
vn
My 89 FORCE 50HP has scored cylinder (bottom) and damaged piston. Not sure what caused it? Can the cylinder be bored with a new piston and larger ring? Should I replace with a short block and where it is available? Is it easy to remove the unit (cylinder/piston)? Any special tool?<br /><br />Thanks for all the help.<br /><br />vn<br />=
