I have a 1988 Force 85HP. The power trim unit leaks down after a few minutes (it slowly got worse), there is no fluid leaking out and the reservoir is full. I have seen some reference to the check valves. Can anyone explain where they are located and if easy to replace ? or are there any other areas that I should check ?<br /><br />Thanks !!!!!!
