Hi I am new to boats. I have an 88 boat with an 85 hp force outboard. I had it in the water 1 day , the next day it would not start up again. looks like it does not have any spark at any of the 3 cylinders. The repaire manual is very confusing.Note that this boat was sitting on land for about 2 years. so far i know that the number 1 ignition coil in open in the secondary side. checked the triger wire and they all have 48-52 ohms. the stator had 740k ohms while still on the motor ***. Now the book says 700ohms.<br />Is there an easy way to find out what is causing this no saprk condition thats clear.Or does anybody have any easy way to find the problem .Should i take the flywheel off and just run a visual check on everything??<br />thanks for the help
