Re: Force 85 no spark
Hello Griswald I had similar problems so I ran a few tests that you may be able to apply.To start get yourself a voltage meter one with at least an ohm meter and dva model preferably.First what color are your ignition packs the tests are the same but the wire colors are updated on on the blue packs and coils.Btw I'm doing this from memory so get yourself a book for confirmed color it should also be printed on a sticker on the motor I don't see an outboard 1990 85 hp only an 89 but regardless I do see a L-drive 1990 85 hp I could be wrong though.Anyway on to the tests.
Some things to consider before doing any tests especially electric, in no paticular order
1 Tools do you have them can you get them and so on.
2 Battery fully charged
3 Someone to help make things go much smoother
4 Remove any and all gas if possible it will make it much safer for electrical testing (keep in mind no fuel means no lubacation) so you'll need to oil the cyliders while when turning over the engine
5 Remove the spark plugs (this will make turn over the engine much easier) ground the spark plug leads to the block, you can use some scrap wire. You can use the open spark plugs opening to inject some oil to protect the cyls.
5 You will need to turn the engine over for some tests
a. If the lower unit is still attached make sure you have ear muffs you cn burn up an impeller real quick I know
b.If the lower unit is off then no worries.
Time out lets do this an easier way
http://www.ebasicpower.com/downloads/cditech/CDI-Troubleshooting_Guide-FORCE.pdf
Good luck shoot me a pm if I can answer anything specific.
