Recently bought an 88 bayliner with 85 horse force. took it out for first time, let it idle in water are 5 minutes had a good spray of water pumping out. Ran it at all differant speeds for about two hours with no problems. When i was waiting for a launch slip open to put it on the trailer i was idling for about 10 minutes and the ?(overheat buzzer)? whent off under the dash. Loaded it up on the trailer tunred key on buzzer still going off. got home about 30 minutes later turned key on no buzzer. NEED HELP checked compression has 130lbs in all 3 cylinders. Next check?????
