250Gimp
Thread starter- Joined
- Jul 13, 2007
- 145
Hi all
We have a 1999 model year Force 75 and there is some milky stuff on the plugs, so I am looking for some help diagnosing this.
Here is what led up to me checking plugs:
Skiing the kids at WOT and on the return trip with the second teenager the engine dropped power to what felt like 2/3 or 3/4 of normal power. (No tach to confirm) Thought I was running out of gas the way it reduced power but it kept going. Skied one more light kid and then pulled in to check things out. 1/2 tank of fuel, new this spring but mixed with a little bit of stabilized fuel from last fall. Pulled plugs and all three have milky deposits, to differing degrees.
Cleaned plugs and did a short run again. Same low power and plugs had milky residue on them again.
Did compression test today and average for each Cylinder, after 3 tests, was 135,138,140 psi.
This doesn't seem like a blown head Gasket, so I ask for your help on this one.
I was wondering if it is possible for the throttle cable to slip, leading to reduced rpm? (No second person to test on the water right now) That doesn't explain the milky residue, which Reminds me of water and oil mixing.
Thanks for your help!
Cheers
Cheers
