bowfish2000
Thread starter- Joined
- Jul 30, 2013
- 2
I?ve recently purchased a boat equipped with a 1997 Force 75hp outboard, the lower unit oil level was low which resulted in the main shaft tapered bearing to seize. The issue is located just above the bearing and just below the water impeller housing is RETAINER-Driveshaft Spline Seal- part # F749271 which is no longer available (OBSOLETE) is busted in 3 pieces and I?ve had no luck locating an aftermarket manufacture for this part, even searched used parts suppliers. I can only assume this motor is now nothing more than a trotline weight.
