My 1998 - 75-HP Force runs not too bad when I use it in the area where I live which is about at 300 feet above sea level... and when I say not too bad I mean that in cooler temp like spring or fales it will be good and smooth accelleration and smooth running at cruising speed.
But when weather gets warm and humid like end of June and July it runs rougher and acceleration is not smooth and strong or if I go fishing out of town in region around 800 to 1000 feet above sea level it will be worst. So last year I made a test I installed a main jet one size leaner which is for the 1500 to 3000 feet range, the original was for the 0 to 1500 feet, and it made a hell of a difference, acceleration better - runs smoother at cruising speed.
The engine is OK all the way - carb clean and well adjusted - timing OK - compression OK - fuel pump OK rebuilt from last year - decarb OK - fuel is 89 octane - plugs NGK-BHW flat surface.
Do you believe I could leave that main jet which is only one size smaller (leaner) in all time ?
Thanks for help.
Mario
Thanks for help.
Mario
