Re: Force 75 ELPT missing and rough idle
Sounds like you've got several problems. First tackle the ignition timing. Easy to correct. The late model Mercury style CDM ignition system should be set to 32? BTDC at WOT static timing method. This is different than the older Prestolite ignition systems which are set to 28? BTDC. You typically don't set the timing at idle, it should be checked at WOT.
Timing is done by adjusting the screw on tower shaft linkage. See the yellow arrow in the picture. The red arrow is the idle speed adjustment.
Next, the lack of spark to # 2 and 3 cylinder at idle. A little tougher but again relatively easy to check. Look up under the flywheel. There should be six magnets epoxied to the inner circumference of the flywheel. Make sure that they are all intact and not broken or missing. See the picture below of the flywheel.
If that checks out, disconnect the Green/White and White/Green wires at the bullet connectors that come out from under the flywheel from the ignition stator. Measure the resistance with a meter between the two White/Green and Green/White wires that go to the stator. It should read between 500 - 700 Ohms.
This is what the stator looks like. There are two versions. The red one as pictured is the good one. There is another version that is black and has a higher failure rate. Note the two Green/White and White/Green wires in the picture. The two yellow wires go to your rectifier/regulator and are used to charge the battery.
As far as the moisture on the bottom plug, it could be the exhaust gasket if you've already changed the head gasket. Exhaust gasket leaks most commonly, but not always affect the bottom cylinders. Also check the stainless steel baffle plate under the exhaust cover for cracks. It'll probably look pretty warped, but this is normal.
