Force 70 hp outboard motor
  • What kind
    Votes: 1 100.0%
  • how much lube
    Votes: 0 0.0%
  • Seal
    Votes: 0 0.0%
  • Total voters
  • Poll closed .
Wildbillchappell
OK what type of lube do you use for the lower unit, need to change the lower unit oil. Don't have manuel to tell me what kind of lube to use, 70 hp force outboard motor. Also THE gaskets for the plugs.
Thanks Bill
baxtr
Re: Force 70 hp outboard motor
Go to your local marine dealer/repair shop, they will have the lube you need and the gaskets for the fill/vent plugs. I use quicksilver because that's what my local shop has. As long as it says lower unit gear lube, should be good
