Force 70 comp. Test
dianamanal
Hi,anyone can tell me how to earth the plugs wires(boots)before cranking the engine for compression test ?tks
jerryjerry05
Re: Force 70 comp. Test
Get about 3-4 ft#10 wire.Cut into 3 even pieces.Strip the wires back about an inch on both ends.Get a connector and put all 3 wires into the connector. Ground that to the block.
Then bend back the other end and strick it into the spark plug lead.
It will ground out the leads.J
JB
Don't bother grounding the plug wires, just disable the ignition. Go to the Engine FAQs Forum and do the Compression Test procedure.
roscoe
Trip the safety lanyard kill switch, it will kill the spark.
