Force 50hp cover removal
gt4turbo78
Hi, I am new to this forum. I just purchased a boat recently with a Force 50hp outboard. It is white with electric start, non-tiller. I can't seem to figure out how to take the motor cover off. Any help would be much appreciated. Thanks in advance, John
Re: Force 50hp cover removal
There should be a lever that you press down on the back of the cowling. Then just lift from back to front.
Good Luck!
Frank Acampora
White force should be the same as the Chrysler: Under the steering snout will be a lever. Turn it--I forget which way-- but turn it and lift the front ,then slide the cover back a bit to release the rear catch and lift off.
gt4turbo78
Got it! Thank you for the fast replies. Came off easily. I was looking at all the wrong places.
