Force 50 Parts Help
JoeSenick
I have just picked up a Force 50 - Model 507X8D, Serial 2402. After reading some other posts, I'm guessing it's a 1988.<br /><br />It runs OK but I'd like to rebuild the carb, fuel pump and water pump if only to have a starting point for future repairs, when needed.<br /><br />Can anyone help with the part numbers for<br />(1) Carb overhaul kit<br />(2) Fuel pump overhaul kit<br />(3) Water pump overhaul kit<br />(4) Thermostat<br /><br />Also, is there anything else I should replace on this motor?<br /><br />Thanks.
roscoe
Re: Force 50 Parts Help
Yes you have a 1988 model, also change the sparkplugs and lower unit lube.<br /><br />You can get parts from any Mercury dealer, like this one:<br /><br />Mercury <br /><br />carb <br /> <br /> <br />Aftermarket (Sierra brand)<br /> thermostat, 18-3556<br />impeller , 47-F4330652<br />fuel pump kit, 18-7806<br /><br />You can get most of these parts here in the iboats mall.
