Force 50 hp spark to only one cylinder
Hello I need help. I have a 1989 50 HP force outboard that i only have spark coming out of one coil. I switched the 2 coils. the other coil fires. so that rules out bad coil. my next guess was the cdi box. i changed cdi box with another one i had that i know was good. no change. so my next thought was the stator. i changed the brown/blue stripe wires with the brown/yellow stripe wires and still no change. so my next guess was the trigger. i switched the 2 sets of wires coming from the trigger and the other coil started firing. does this mean my trigger is bad?? i have another trigger that have solid color wires, hooked that up by cross referencing the color codes still no difference. i need help because i have a fishing tournament next weekend and really needs to be running by then. all help would be appreciated.
Re: Force 50 hp spark to only one cylinder
i forgot to mention to mention that if the stator would happen to be bad, i have one but it only has 4 wires. two blue and two green with yellow stripes. is there anyway this stator would work with this engine.
roscoe
my bet is on trigger
i think it is to. im gonna order one today. how do you test one.
Rickybilly
Hello all. Seeking help. I'm am new and clueless to the boating world. Two days ago I purchased a 1980 20 hp Chrysler O/B motor from craigslist for 60.00. I have hopes to get it running great and put it on 18' alum boat.
It's elect. Start w/ key and it turns but does not turn over. When push key , carb opens and closes. Getting gas fine. Good compression. I don't think no spark in plugs. What to do? Do I need to buy a puller to pull off top drum from motor? What is a stator, trigger, and rectifier???
Do I need new electronic box w/ harness??
I need help. Anybody. Thanks folks.
