Force 50 hp - 1990 gear problems
richiwatts
I recently bought a bayliner 1990 that has a Force 50 hp from the same year.<br /><br />Last week I started getting the problem that if I put it in neutral after driving it still moves forward (very slowly).<br /><br />Now I can't get it into reverse. It just revs like crazy and when I quickly put in back into the neutral position the boat jolts forward slightly and then continues to move forward slightly.<br /><br />What could be causing this? I have ordered Seloc but I doubt I will get it for another 4-5 days.
roscoe
Re: Force 50 hp - 1990 gear problems
There is a shift rod that connects to the lower unit, it may not be adjusted correctly. A little tricky to adjust. <br /><br />Covered on page 473-474 of Clymer manual.<br />Not sure about the SELOC MANUAL.
