force 40hp wont turnover due to very high compression
jason32038
Re: force 40hp wont turnover due to very high compression
A weak battery can kill these starters if overcranked. Just like if an electric d/c motor has an undersupplied current it will damage the motor. I would start with a new battery and new connectors both on the powerhead side and at the battery.
sx3
Hi Guys. An update on my Force 40hp with high compression that wont turnover. I have found the cure. Although battery was fully charged I replaced it with a higher cranking amp model, from 250cca to 450cca and hey presto she spun freely and started first pop. It now starts first time every time. I also relaced pos cable to solenoid although upon cutting open the cable was clean, no corrosion. Thanks for all your help:
GA_Boater
Thanks for the follow-up, sx. Very few ever do that. Glad it turned out to be a simple fix.
jason32038
Wow I didnt even know they made 250cca batteries...sounds like something that would be in a riding lawnmower. Glad you fixed your problem!
sx3
Hi. Yes down here in kiwiland we have 250cca batteries in our vehicles. No yank tanks!! Yep she turns over nicely now. Thanks:rolleyes:
