eurolarva
Thread starter- Joined
- Jun 24, 2003
- 4,182
As you turn key to the full clockwise position you are still pushing the switch in? And as you push the key in you loose power to the choke solinoid? Behind the ignition switch is some letters. What color wire is going to the C and what color wire is going to the S? When motor is running will the key shut the motor down when you turn it to the left to the off position?
