Downrigger
Thread starter- Joined
- Feb 15, 2006
- 42
Went fishing 2 weeks ago and tried again but the motor would not crank over. Changed the starter, removed the plugs still would not crank. Plugs had "goo" on them. Sprayed the inside of all the cylinders with WD40 and after several tries tries got the engine to finally break loose and turn over. Cleaned and replaced the plugs and it started right up and ran fine. I have been adding a little more 2 stroke oil recently (maybe more than a little more. Maybe too much oil and things got gummed up inside after it sat for 3 weeks? Id that a possibility. I don't see any evidence of water contamination in the cylinders or on the plugs (rust, etc) and what blew out of the cylinders seemed clean (oily but clean) when it finally cranked over. It just seemed to be gummed up and it took the WD40 in the cylinders to free it up. It did smoke a lot when it finally started.
Any ideas what the problem is besides too much oil left in the cylinders after shut down.
Thanks,
Larry
Thanks,
Larry
